1999 XK8 Convertible Top won't rise / retract
Old 05-19-2016, 08:20 PM
Hi-Velo-Sid-E's Avatar
Are you guys dizzy yet? I know I am!
Old 05-19-2016, 08:29 PM
I can't believe how much they complicated this convertible system with computers, hydraulics and sensors just so the user wouldn't have to manually latch the roof when raised, not worth all the potential headaches, in my opinion anyways.
I've had American convertibles and never had any problems whatsoever, even with the older ones.
Old 05-19-2016, 08:44 PM
Gus's Avatar
Gus
Gus is offline
Received 2,214 Likes on 1,703 Posts
Did you do a hard reset when the roof was open and the latch parked?
Originally Posted by Hi-Velo-Sid-E
So now with the roof fully retracted and the latch now locked
- valve closed
- reconnected neg terminal
- Started car
- lowered front windows until clicked
- pushed button-roof up, nothing happening, no response, no pump, nothing
- pushed
button-roof down, pump runs and latch opens, roof doesn't rise, then get message "latch not closed" even though roof is down
So either way roof stays down and doesn't rise and system is still confused and dumb as heck!
- so I opened the valve
to release pressure then raised top manually
then closed the valve
to try to bring it to the latch and raise the windows, still nothing and back windows now don't rise
so with top still manually raised,
- Pushed button-roof down, after waiting long enough top lowers towards latch, and I think I latched it manually with the hex key, don't quite recall
So I turned off ignition, this time I firstly disconnected neg terminal
- opened valve
- unlatched
- manually retracted top again, oddly I didn't have to unlock the rams again
- closed valve
- closed latch
Though somewhat confused at this point, I'm now waiting and desperately hoping it might work this time after having firstly disconnected the neg terminal, may be that's what the issue is?
Thank you
Sid
Old 05-19-2016, 08:49 PM
The latch was not locked/parked prior to the neg terminal being disconnected, but i did park the latch prior to reconnecting the neg terminal.
Old 05-19-2016, 08:50 PM
Gus's Avatar
Gus
Gus is offline
When you pushed the button to close the roof did the latch come open? Did the pump continue to run after the latch came open?
The windows will not close until the rams are fully extended to the locked position.
Old 05-19-2016, 08:52 PM
When i pushed the button to close the roof, nothing happened at all, no pump noise or anything, like if I had not pushed the button
Old 05-19-2016, 08:55 PM
The rams didn't lock when I close the top and latch it manually.
  #28
Gus's Avatar
Gus
Gus is offline
So the latch did not come open
Old 05-19-2016, 08:57 PM
It eventually did when i pushed the Button-top down but nothing happened when i initially tried button-top up
  #30
Old 05-19-2016, 09:01 PM
Gus's Avatar
Gus
Gus is offline
When the roof was open and the latch was parked and you did a hard reset did the pump run and did the latch open and did the pump run with no movement of the roof?
  #31
Old 05-19-2016, 09:04 PM
my initial problem was that
with roof up - the button-down didn't lower the roof
but Button-up worked to close the roof and latch it, then it raised the windows.
now the button-up doesn't work at all
  #32
Old 05-19-2016, 09:08 PM
Gus's Avatar
Gus
Gus is offline
I understand that! So you are saying that you have nothing now. No movement to open the latch and close the roof?
  #33
When I did button-roof up - nothing at all happened
I only got pump response and latch open on Button-roof down while roof was still down
thanks
  #34
Old 05-19-2016, 09:11 PM
Gus's Avatar
Gus
Gus is offline
Have you done anything with the pump or the electrical to the pump?
  #35
Old 05-19-2016, 09:12 PM
Yes, exactly!
but if I raise the roof manually and then push button-roof down and insist/wait long enough the roof goes towards the latch, so when pushing button-roof down and i do it long enough it will do the opposite of roof down and actually push towards the latch
  #36
Old 05-19-2016, 09:13 PM
no, nothing
  #37
Old 05-19-2016, 09:15 PM
originally, the pump activated when i pushed button roof up or down, the only issue was it didn't lower the roof
Oh and it lowered and raised the windows no problem
  #38
Old 05-19-2016, 09:19 PM
I'm going out now to reconnect the the neg terminal and try it again.
I'll be right back with the result
Thank you
  #39
Old 05-19-2016, 09:22 PM
Gus's Avatar
Gus
Gus is offline
Ok I am done for the night. My brain is full!!
This system is controlled by 2 computers, 5 switches, 2 control valves, 2 relays and one pump that is bidirectional and ALL must be in sequence to make it work. This system is easily confused by pushing the open/close button over and over again and by opening the roof when it thinks it is closed and that is the reason for the hard reset when it is open and the latch is parked.
I will think about this in the morning!
Hi-Velo-Sid-E (05-19-2016)
  #40
Old 05-19-2016, 10:37 PM
Hi Gus, just got back and saw this message.
Good night and thanks again, much appreciated
