1999 XK8 Fuel Door Actuator
Am I seriously to believe that Jaguar "installed" this part on a $70,000+ car with two-sided tape? No screws, bolts, or brackets? I got a replacement actuator but of course it did not come with the expensive plastic nut that holds it on. I just ordered one of those also. Because I did not want to risk the fuel door being open and someone catching it on the way by, I taped the actuator to the inside of the fender and then, wait for it, wrapped a kitchen twist tie around the neck that protrudes into the fuel door and latches it shut!!! It worked. Now when the actual nut comes, I simply remove the twist tie and install the nut. Hopefully, it is in good used condition and will hold sufficiently.
DavidYau (08-26-2022)
