1999 XK8 Rear View Mirror Fix?
Has anyone ever tried replacing with a newer mirror and just re-wiring white plug to yellow plug?
- What year model had the fixed/good mirrors after the recall?
- Why couldn't you purchase a newer white plug 6 or 8 wire mirror and remove those wires and then re-install into an older yellow plug matching colors as I go?
- In my case, I would have to buy the newer white plug mirror and then also buy a yellow plug since mine has been cut off.
- Does anyone have a 1999 wiring schematic for mirror with auto dimming and auto headlights?
- Is there a better way to approach? I mainly want the auto headlight feature to start working.
I guess I mis-spoke when I said Recall. Surely there is a cutoff year when mirrors started being OK and did not need to be replaced. Current mirror has wires cut and was installed by previous owner. I have no idea what I have.
With answers to my questions, I might be able to retrofit a newer mirror with old plug.
Thank you for your detailed answer. That's what I'm looking for.
Do you know what year the mirrors actually started being good and not failing? Or was there such a year?
If I only care about getting the automated headlights to work, I would only need the three wires in BOLD. Correct?
White/Red = +12V (same on 1999)
Black/Pink= Ground (same on 1999)
Yellow= Reverse light (Yellow/White on 1999)
Yellow/Blue=Auto headlight (to light switch) (same on 1999)
Blue=Tint (to side mirrors) (Purple/Black on 1999)
motorcarman (10-19-2022)
