1999 XK8 Throttle Body
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
My dealer has diagnosed a defective throttle body on our XK8. Is there any place that sells original parts for less than $2100-2400? Does anyone have any experience with british parts place on e-Bay? Because of the high cost of this part, I am considering replacing the engine and transmission with a Chevrolet 350 engine and trans. I appreciate any help/advice you can provide.
This company will rebuild your throttle body for $489: ASI - JAGUAR-S-XK-XJ-97-to-03-THROTTLE-BODY-REBUILD-SERVICE
gkirkland (03-18-2012)
I recently had my TB rebuilt by ASI this link might help if you wish to do it yourself JagRepair.com - Jaguar Repair Information Resource
The battery should be disconnected when replacing the TB. The ECM (Engine Control Module) then sets a default engine mapping and 'learns' the new TB as you drive.
Especially make sure the four electrical harness connectors to the TB have all been reconnected properly.
If you missed this step, disconnecting and reconnecting the battery will have the same effect. Not too sure, but I think it may need to be left off for a few minutes to lose anything stored in memory.
gkirkland (04-29-2012)
Not sure what gallops means but if it means it's running too fast, you might have a bad vacuum leak.You might check with the rebuilder to see if there is any reason to send it back to them to be looked at.
We now havw a different issue. After the throttle body was installed, we ran the car for a week without any issues. Now, it heats up very quickly; it seems to build up pressure in the cooling systerm to the point that coolant is forced out of the system. Also, the engine now idles very rough, almost like a cylinder is not firing.
Does anyone have any suggestions? Is this related to the throttle body?
Investigate immediately - the V8 doesn't take well to overheating.
+1 My Thermostat Failed Abruptly. Radiator Cooling Fan Ran at High Speed at Engine Shutdown. Replaced Thermostat, all is well. In my case the (Infamous) Engine Temp Gauge DID NOT show High Temp.
I have a question. I have looked all over this form for direction, I am taking my intake manifold off to replace gaskets as I have lean bank codes.. at the same time I want to clean intake and change heater hoses, thermostat, water pump and housing.. question is I can not for the life of me get the throttle body electrical connector off. I do not want to break it as it is already starting to crack. does any one have a diagram on where to press or squeeze to get this connector off. I have posted a picture. The connector with the arrow on the left. 1999 xk8 conv. 4.0 , thanks in advance.
xk8florida (02-10-2013)
I do not see a tab. there are notches on the top, but no tab. I am sure I am going to break this thing as it has cracked in the back and blue wire connectors are starting to show. I am still trying to find a exact picture on the net some where of how to take this off. scheduled time for this today and this is holding me up . thanks for the quick replay Gus.
