1999 XKR engine having trouble to heat up, thermostat is 6 months old
In June I've changed thermostat, and the car was running good until December. Now sometimes it works on proper temperature, sometimes not. Sometimes temp gauge goes from the middle to zero (fully cold engine) in 10 secs, then it goes back while im driving. Most of the time temp is about 5 mm lower that it should be. The car is running rich, sometimes having trouble to start in this cases. Is it faulty thermostat again?
Consider the OEM Temp Sender is probably original, suggest you replace it . The thermostat, being new, should not be defective so soon. If you have access to a infrared heat check the thermostat housing for the temp after engine reaches operating temp. Then look at your gauge for its reading. The gun and gauge should be very close.
Keep in mind that the dashboard temperature gauge is NOT an exactly correct indicator of engine temperature. Apparently it is designed to track the engine temperature from startup to normal operating temp. But then, when the normal operating temperature is reached, the needle "freezes" at the straight up position, so that normal (small) variations in engine temperature are not shown --- the needle stays exactly straight up. However, if significant overheating develops, I assume that the needle will "unstick" from the straight up position, and move up. Many owners might never see this happen (I haven't).
Also, this engine can be very slow warming up in very cold conditions (well below freezing). Normal operating temperature (needle straight up) may never be seen on short trips when freeway speeds are not achieved.
It seems possible that what you are seeing could be due to a fault in the gauge itself, of its circuitry.
Bob Frisby
1999 XK8
Boise, Idaho
Bob Frisby
1999 XK8
Boise, Idaho
Received 1,692 Likes
motorcarman (01-30-2023)
UPDATE:
I was sitting in the traffic jam, hearing some noises. Then when I moved along the temp gauge went to the red line, and the engine boiled. Mechanic told me that I was missing 5 litres of coolant, and after he changed a coolant cap he said that the car started to work good and each working temperature. (So my coolant level sensor is broken). The car is able to hit the middle of the gauge and good fuel milage only while randomly cursing along the town, sometimes. Neve on highway though
I don't think it is the gauge problem as I experience like 40l/100km fuel milage.
I don't have a real gauge, it is a stock one
My guess is the coolant temp sensor, but I am not sure
Johnken (02-08-2023)
I would recommend asking the mechanic where the missing 5 quarts of coolant went ?
That’s about 50% of the coolant capacity. It should be of supreme importance to trace how and where that much coolant disappeared.
If you don’t solve that mystery it’s likely to happen again.
Z
Z
the car is fitted with k&n air filter, but I’ve never heard that it can affect the engine temp
kstevusa (02-22-2023)
garethashenden
10-29-2016 04:32 PM
