1999 XKR transmission oil change
I've done some research on changing the transmission oil on my 1999 XKR and it doesn't seem too much of a problem. I'm going to buy an IR light to get the temperature of the casing (I read somewhere on that it will read 10% lower than the computer hookup, I presume due to reading the casing temp) and the parts / oil look reasonable if I do this myself.
I know I should flush the transmission but can't find any info on the procedure for doing this. Can anyone give me some advice.
Regards
Steve
Regards
Steve
TIP FOR TRANS FLUID TEMP-
When I did my trans fluid change I had heard the same thing about case temp versus actual temp of fluid so I used the infra red temp gun and averaged the temp of the fluid draining out and the case temp and it worked well for me.
Good luck and get the chassis level before you start.
Barry
Barry
Beardy
09-18-2015 10:00 AM
