20 inch Jag XF wheels
iirc the rear ET was 46 not 66 mm. The ET values are usually stamped inside the wheel.
Both paragon and adamesh have adaptors:
Paragon Design UK - Jaguar XK8 & XKR Wheel Spacer Adapters
Jaguar XK8 XKR Wheel Adaptors
The ones from paragon require some work on the wheels, and are relatively thin (so the rear comes in about 6mm, the front is iirc about right). The Adamesh ones as you can see are very thick, probably pushing out the wheels more.
Best to check the thickness with both to be sure.
Just a few days ago I made an inquiry about this set:
https://www.jaguarforums.com/forum/p...wheels-116780/
It really is 66mm on an XF, at least for the staggered wheel setup. I was surprised it was so large an offset.
On an XK though, it is more like 36 and 46.
It turns out my dad bought a 2010 XF supercharged, but he doesn't like 20" wheels, he says the profile of the tires is too small. He wanted to give me those wheels so he could buy a set of 18" wheels. Either way, one of the rims is severely damaged and soldering provides a temporary solution.
