I'm replacing the engine in a 2000 XK8. I have removed the engine and transmission together once from the top. I was wondering if it would be easier to take it out from underneath.
What I have to work with is a 2 post lift and an engine hoist.
I was thinking that if I get the car on the hoist and disconnect or remove what I need to get the engine and transmission out, except the subframe and the rear mount for the transmission, then lower the car onto a 2' tall table with wheels. Then take the subframe and transmission mount loose, then lift the car and leaving the engine and transmission on the table. Roll it out from under the car, then use the engine hoist to remove the engine and then install the replacement engine to the transmission and reverse the procedure to install the pair into the car.
I was looking for a few opinions on the best way to go. Out the top or out the bottom.
I would only do I that way if lifting the powertrain was going to be an issue either from the vertical clearance in the building or the lift height of the hoist. Whilst it has the attraction of being a more straightforward lift, the additional work involved in disconnecting subframe and steering is likely to take a lot longer than the traditional way out of the top.
It was a couple of weekends ago but I got the engine out of the car. I used Bob's, Motorcarman's, suggestion of removing the engine from the bottom of the car. I made a table with wheels to place the engine, subframe, transmission combo on. As Bob mentioned the steering column was a pain. I couldn't get the engine around it. I went under the dash a disconnected the short shaft that goes through the firewall. I was then able to take the short shaft, now completely loose, and push it into the cabin enough to get the engine to clear.
As I'm looking at the subframe sitting on the table I saw how easy it will be rebuild the front suspension, it is still original. I ordered new shocks,upper shock mounts, and bushings. Been working out of town so it might take me a month or so to get this back in but I'm in no hurry.
The engine is from my 99xk8 donor car that was in an front end accident. I have never started the engine but it must have been running when he rear ended the car in front of him.
Saw this late, but I use one of the Hydraulic tables (1500 lbs) from Harbor Freight. Makes it easy to move around,and you can lower /raise it as you work on the engine.
I built the table myself because that is how I do things.
I made it so it is big enough to hold the combo and also narrow enough so there is access to the subframe bolts that need to be removed after the table is supporting the weight of the combo.
I have a friend that owns a stainless shop. I will have him make me a heavy gauge galvanized top fo it and I will build storage shelves underneath it.
When I'm done with the table I will sign it " Shade Tree Bob". Once on the site someone jokingly call me a shade tree mechanic.
Crap to my wife is gold to me.
2- Yamaha FJ1200 motorcycles
Babygrand race car
2 welders
Scaffolding
3- tonneau covers for xk8- 2 black and one cream
Set of tires and rims for 97 xk8.
The crap is on the opposite side of my shop, my wife's "crap".
Everytime I throw away some CRAP, I end up looking for it a few weeks/months later and then remember that I threw it away!!!
I don't throw much away anymore!!!!!!!!!!
People can throw it away after I'm GONE!!!!!!!!!!!
