2000 XK8 Gas Cap problem
Guest
Posts: n/a
Guest
Posts: n/a
Well the gas cap can be loosing pressure which would cause the gas tank to loose pressure. This would trigger a sensor. Its intended to tell you if you have a crack in the gas tank, but they proabably looked at that and noticed nothing wrong and said it was the gas cap. Thats my guess,
-Mike
-Mike
Been chasing the P0455 leak code for two years. Replaced gas cap, purge valve, other valve. Found missing o-rings in left side filter cannister, loose hose at engine. Still haven't solved the problem. My mechanic hasn't charged me for anything in a while but he also hasn't found the problem. Very frustrating.
