2000 XK8 leaper emblem
Old 10-12-2021, 06:17 PM
bcprice36's Avatar
Markmbaha1,
I hope you aren't making fun of my MBA...with that Name....Anyway, Mark your situation is very simple....Just remove the Chrome Backing piece from the Fender (Wing) and replace it with the new Part that you want to take the Jaguar off of...That way you don't have to remove anything but the Chrome Base from the Fender!.....After all, it's just Glued/Taped on...Now you don't have to remove the Jaguar from the Chrome backing!!!!
Hope this answered your question...!!
Billy Clyde @ Cinco Ranch
Old 10-12-2021, 08:23 PM
Markmbaha1's Avatar
Originally Posted by bcprice36
Markmbaha1,
Lol, no I have one too. Part of those letters are the first letters of an organization I loved working for.
I guess I'm not confident how to get it off without making a mess of the paint. If the old tape sticks how do I clean it off the body? It feels solid stuck on, what is the safest method of removal.
Thank you
Mark
Old 10-13-2021, 09:52 AM
MRomanik's Avatar
Thank you
Mark
I used fishing line when I replaced mine last year. I came off easily, very little residue.
Markmbaha1 (10-13-2021)
Old 10-13-2021, 01:35 PM
michaelh's Avatar
Received 2,393 Likes on 1,552 Posts
+1
Warming it gently with a hairdryer helps too.
Old 10-19-2021, 06:37 PM
Markmbaha1's Avatar
Electric wire was attached to backside center of the leaper chrome part. Do some of these have a light? It does not plug into anything, the hole is empty.
Old 10-19-2021, 07:34 PM
bcprice36's Avatar
Markmbaha1,
As I said: The Early XK8's were wired for "Turn Signal Blinkers"! Those wires are found inside the Fender Wells so that you can change over to Blinkers if you want......The Wire end doesn't look right on the Photo of the Wire, so you may have to find an XK8/R in a Wrecking Yard or go to a Jaguar Parts Company to get the proper Part....Also, you will have to Buy the Blinker from eBay or someone like that or just ignore the Wire and let it hang lose in the Fender Well....That way you can just reinstall the Leaper and forget about the Light.....It's up to you...........
Billy Clyde @ Cinco Ranch.
Markmbaha1 (10-19-2021)
Old 10-19-2021, 10:55 PM
Markmbaha1's Avatar
Thank you. I think it would be cool to illuminate the leaper.
  #28
Old 04-30-2022, 09:21 AM
Likeshuz's Avatar
Default Help me guys
so, remove pic A using hair dryer/dental floss/fishing wire/putty knife? Then there should be comparable holes for new emblem?
Old 04-30-2022, 09:22 AM
Likeshuz's Avatar
Oh, does it matter, if mine is 99?
  #30
Old 05-01-2022, 05:53 PM
bcprice36's Avatar
Likeshuz............
The Leaper is attached to the Fender with (2) Way Tape...Just pry it lose with Fishing Line....There is an oval-shaped hole in the Fender under the Leaper....also in most cases there is wiring, which runs to the Blinkers.....If you hook that wire up to a Blinker-Light Like all XK8 & XKR's have from about 2000 on....You can also have Blinker signals.....You will have to Buy the Blinker Light from one of the Jaguar Accessary Sells Shops on Ebay or the Internet...You cannot make the "Leaper" light-up!
Billy Clyde
pezzonovante88
02-26-2023 04:17 PM
rlozano
11-20-2018 01:52 PM
Skyjump136
02-04-2014 01:30 PM
tzvangel
04-04-2011 02:27 PM
searanch
60
07-15-2009 01:56 PM
Quick Reply: 2000 XK8 leaper emblem
