2000 XK8 wont restart after running - intermittent fault
My low mileage (30k) XK8 which I've owned from new has an annoying intermittent fault where after a long or short run and switch off it wont restart. Leave it 20 - 30 mins and it restarts and runs fine. Its had a new fuel pump a couple of years ago (my model only has one pump). It cranks well but wont fire. Its not old fuel.
Any ideas as to what cause may be? Any similar issues encountered by anyone?
Very frustrating and stops me using it. Help please.............
An ODB scan might provide a clue, or it might not with older cars, so you need to try and narrow the problem down. Perhaps the easiest first check would be to check a spark plug after a failed start. If the plug is damp or smells of fuel, then it's probably an ignition problem. If it's dry you could remove the intake pipework from the top of the throttle body and spray in a little fuel whilst it's turning over. If it fires for a second or two, then it's a fuelling problem. Once you narrow down the issue, you can perhaps make more progress.
Richard
Richard
jag67
09-21-2019 02:03 AM
