2000 XKR coolant reservoir
My Jag has been parked for 4 months do to the Norwegian winter.
Recharged the battery and started the car yesterday, but after 10-15 minutes it started to smoke quite well from the engine. It turned out to be a coolant leak at the reservoir.
The temperature has been between -20 to -30 degree C (-4 to -22 F) for several weeks, so that could be a part of the problem.
The question is; will you recommend the original part or are the aftermarked reservoir just as good?
A few years ago there was a recurring problem with the aftermarket ones incorrectly showing low coolant levels - I had one of the troublesome ones from SNG Barratt and they kindly replaced it with a genuine part at no additional cost, because of the widespead problems.
I don't think the genuine part is much more exoensive than aftermarket, so I'd suggest a genuine part (unless they are horribly expensive in Norway).
The OP is after a coolant bottle, not a washer bottle. I would not suggest a used coolant bottle beacaue they all leak eventually and a used one is a false economy if you then have to buy a new one a month later. Coolant loss and a damaged engine isn't worth the gamble for a few quid.
Abby's Guy (03-01-2021)
BCP
G.M. Webster
12-11-2019 09:28 PM
kblood
06-21-2010 09:43 PM
