2000 XKR ECM replacement
Old 05-26-2012, 05:49 PM
iriddles's Avatar
the throttle pedal position sensor was bad on my throttle body. no electrical current thru it. not a replaceable part. if it or the throttle position sensor go out you have to replace the entire throttle body. that really generates profit! i think something happened in the ecm that fried the tpps electrics. the service writer (not very mechanically minded) wouldn't let me talk to the tech that worked on my car (superior british service management). i was a franchised dealer for 23 years so i understand where that comes from but i also understand there are times that causes ill feelings with the customer. i met the tech briefly when i dropped my car off and had a good feeling about his abilities so i was not worried. the repair order stated that they performed "immobilization procedure" which i think just gets the ecm to recognize my car and its electrics. i figured avos and blackx300vdp know what they're talking about.
Old 10-17-2012, 04:53 PM
Super Cat's Avatar
2000 XKR VIN A02935 - My ECM is LNF1410AC. If I understand the above number scheme a LNF1410BC should work. Am I right?
Old 10-17-2012, 11:39 PM
avos's Avatar
Received 1,068 Likes on 761 Posts
Don't think so,for your car only the last possition may change not the 2nd last.
Super Cat (10-18-2012)
Old 10-18-2012, 03:51 AM
seawind's Avatar
Now I take what I am told from the Jaguar ***********s with a grain of salt but I was told by two Jag Dealers that the 2nd to last letter must stay the same in my case and in your case that's the A. You need either a LNF1410AG or LNF1410AC they should both be compatible for a XKR there may be more revisions but I've never seen or heard of them.
I do have 2 spare ECMs that are "LNF1410AC" if you want one just send me a message I'll give you a good price. My problem ended up being a bad instrument cluster not an ECM....
--Ryan
Old 10-11-2015, 04:39 PM
targahs1's Avatar
Default spare LNF1410AC ?
[QUOTE=seawind;602837]Now I take what I am told from the Jaguar ***********s with a grain of salt but I was told by two Jag Dealers that the 2nd to last letter must stay the same in my case and in your case that's the A. You need either a LNF1410AG or LNF1410AC they should both be compatible for a XKR there may be more revisions but I've never seen or heard of them.
I do have 2 spare ECMs that are "LNF1410AC" if you want one just send me a message I'll give you a good price. My problemu ended up being a bad instrument cluster not an ECM....
Old 10-11-2015, 04:42 PM
targahs1's Avatar
Hi , I would be interested if you still have one.
Old 10-12-2015, 05:36 PM
seawind's Avatar
If I remember correctly iriddles bought one. I am to lazy to ever list anything on eBay so I probably have the 2nd one in the garage somewhere... pm sent
Beardy
09-18-2015 10:00 AM
tberg
09-07-2015 07:32 AM
nelsonht
08-30-2015 06:01 AM
TC Johnson
08-29-2015 08:55 PM
peterg19
08-28-2015 08:42 AM
Quick Reply: 2000 XKR ECM replacement
