2000 XKR oil loss 4-5 Qts in 3300 miles
Old 03-17-2010, 02:15 AM
ragtopXKR's Avatar
Update: I'm almost done replacing the engine in my XKR. The crankshaft was far too damaged to rebuild and metal particles went all through the system. I purchased a rebuilt long block from Auto Sports Unlimited for $4500 plus shipping. Water pump, O-rings, thermostat, valve covers have added several hundred dollars more. The long block does come with a 12 mth/12000 mile parts warranty. I've spoken with several dealers and no one has heard of this much oil consumption and the consensus is that it was not filled correctly. Mobil 1 Lube express has been no help at all so I've given up and hired a lawyer. Replacing the engine is a very big and time consuming task so I would suggest avoiding these guys!
Old 03-17-2010, 02:16 AM
ragtopXKR's Avatar
What is the proceedure for purging air from the cooling system. I've been told to open the large hex plug in the super charger cooler and run the engine but would like more detailed instructions.
Old 03-17-2010, 01:02 PM
H20boy's Avatar
Received 1,151 Likes on 753 Posts
You may have better luck ragtop with your question in another thread, this one deals with (and is titled) around your oil loss, and may not get the response you need.
good luck.
toronadomike
08-07-2022 03:41 PM
kelliott
05-31-2022 05:26 PM
Beardy
09-18-2015 10:00 AM
pnwrs2000
09-03-2015 11:55 AM
XFR_Gold
09-02-2015 12:24 PM
Quick Reply: 2000 XKR oil loss 4-5 Qts in 3300 miles
