2000 XKR / XJ8 differential comparison
Hi all! As always, Thanks for all your help.
How does the 2000 xkr and xj8 differential compare? I found a unit from a 98 xj8. Can I exchange the driveshaft flange, modify the shaft on the pinion on the xj8 by cutting it off?
I replace the differential assembly in my 2002 XKR100 about three months ago. Like you,I found one that was set up for a donut instead of a flange. I cut off the snout and installed the flange from the broken diff. I wanted to just replace the ring and pinion but could not find the pieces. Supposedly it is a DANA unit actually made by *** in Germany.
FS[UnitedKingdom]: Xkr rear bumper 2007
fourlcars
12-07-2015 06:35 AM
