2001 jaguar XK8 AC bypass belt
Received 6,327 Likes
Welcome.
There is no listing I can find for that car WITHOUT a/c, so obviously NO part number in any system.
The original belt is a 7PK2320, so its 2320mm long, simple.
Basically measure around the pulleys youi want to include, and go to a parts shop and give them the length you have worked out, and it has to be a 7PK spec belt.
You will make many, many trips and try many, many belts, until success strikes.
Good luck.
Good luck.
Received 3,964 Likes
If it is possible and there is a belt available, members here with the same model are the ones likely to know.
