2001 jaguar xkr cuts on and cuts right back off. Help
I have a 2001 jaguar xkr. The vehicle will crank up and turn right back up. I check the fuel pressure it's shooting out the rails. Change the mass air flow sensor. It still doing the same thing. I got a code for a air control valve and map sensor too
You should check your fuel pressure with a gauge. If it is just sqirting out you may have some pressure, but not necessarily the right pressure or enough fuel volume.
Also remove a spark plug or two and check if the plugs are wet (flooded with gas) or fouled.
While you have a plug out, ground the metal shell to the engine while someone cranks and make sure your ignition is not going off.
BrentGardner
28
04-26-2024 03:08 AM
FS[NorthEast]: Jaguar XKR Wheels for Sale
Griffbritgreen
07-27-2016 05:43 AM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
