2001 XK8
Guest
Posts: n/a
2001 XK8
i'm experiencing the following problem today.
1. trunk does not open by hitting the trunk release by the steering wheel.
2. trunk does not open by hitting trunk release on the key
3. trunk does not open by hitting truck circle on trunk
i can access the trunk by using the trunk keyhole between the "X" and the "K" on the rear of the car.
4. gasflap will not open byhitting gas flap release by thesteering wheel.
i canopen gas flap through the trunk.
5. sunroof will not open by using the sunroof buttonin the center console.
6. sunroof will not open by key when i place the key in driver'sside and turn to the right.
7. none of the buttons on the 1st key will work (door lock, door open, trunk release)
8. none of the buttons on the 2nd key will work (door lock, door open, trunk release)
