2001 xk8 headgasket replacement
Received 2,400 Likes
That's going to keep you out of mischief for a while ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
I've attached the JTIS cylinder head R&R, but I recommend you download the 2nd edition Workshop Manual from the stickies here:
https://www.jaguarforums.com/forum/x...00/#post201829
Do a page search on 'workshop'
You're going to need a timing kit, and something to break that wretched crank bolt free (replace with new). I don't see any cooling parts in your kit, so consider replacing any/all rubber and plastic components as part of the job - particularly the valley hoses & the thermostat tower while you have the top of the motor apart.
Does the car still have plastic tensioners?
zray (12-13-2023)
