2001 XK8 just completed upper and lower timing tensioner rebuild, car now wont start
Old 01-13-2017, 05:54 AM
Diywannabe's Avatar
Default 2001 XK8 just completed upper and lower timing tensioner rebuild, car now wont start
purchased this vehicle about 3 months ago. just replaced the primary and secondary tensioners, water pump, thermostat housing, new plugs. everything went fairly smooth, no major issues. car had no issues before we began, no codes, running well. upon completion, cant get the thing to turn over. checked the schrader valve on the fuel rail , showing n o fuel pressure at all. fuses and relays appear to be ok, inertia switch hasnt been tripped. any thoughts on cause and solution regarding this issue would be greatly appreciated. thanks
Old 01-13-2017, 07:26 AM
bladerunner919's Avatar
So it won't turn over at all? I assume dash lights come on ok? How's the battery?
Old 01-13-2017, 10:03 AM
phanc60844's Avatar
wont turn over? or wont start?. did you remember to remove the timing peg on the flywheel and put the sensor back in? you should have tried to turn it over on the starter first with the fuel pump relay removed to build up some oil pressure to preset the tensioners. Then put it back and try a start. Not sure if you have done that?
Old 01-13-2017, 03:18 PM
Diywannabe's Avatar
the car is turning over, wont start. the sensor was put back, wil lremove the relay this pm
Old 01-13-2017, 03:27 PM
Diywannabe's Avatar
dash lights work fine. rercharged the battery, was putting out 12.6v. did a hard reset before reconnhecting the cables
Old 01-13-2017, 03:29 PM
Diywannabe's Avatar
im sorry, engine is turning, wont start.
Old 01-13-2017, 03:37 PM
RJ237's Avatar
Received 2,805 Likes on 2,238 Posts
It could be the fuel pump fuse, relay or the pump itself. The fuse is a 20 amp located in the trunk and the relay is there also. Swap the relay with another one and check the fuse.
Poet
04-11-2022 06:51 PM
Christopher Gleockler
01-12-2017 11:30 AM
Tjag253
12-30-2016 09:16 AM
BodmanRae
12-04-2016 07:51 AM
wymjym
11-05-2016 07:56 AM
Quick Reply: 2001 XK8 just completed upper and lower timing tensioner rebuild, car now wont start
