2001 XK8 Radio Power Missing
Welcome to the forum pilot435,
I see you've been a member since December 2013 but this is your first post.
Eliminating the obvious one - the rotary VOLUME switch on the head unit is PUSH to power ON and OFF. You certainly wouldn't be the first to miss this.
pilot435 (04-16-2016)
The common problem when jump jump starting this car is starting using another car that has its engine running. This causes malfunction of the voltage regulator, and typically the radio is the first victim. That is why the owners manual specifically states that the donor car must not be running.
Used headunits are available on eBay for a fairly reasonable cost if all else fails.
I have bought a radio but haven't bothered to install it yet. By the way - many advertisers say the XJ & XK radios are the same, but they're not because the front panel is a different shape.
