2001 XK8 x100 occasional high RPM to 4000 and car stalls
Welcome to the forums Mitro,
I've moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to help.
Thank you for your guidance Graham
I live in New York but I have a 2001 Jaguar
xk8 x100
vin SAJAA41M41NA20268
I am restoring it and need help with
trouble areas and parts
Any help from the forum and experienced
owners would be appreciated
Also I am not too savvy on following
your instructions to fill out further details
on my profile
best regards
john
xk8 x100
on my profile
best regards
john
I would like to know more about what state the car is in...
One,,, is the car completely new to you?
Have you been working on it a while?
Have you ever seen it run, normally?
Do you have a complete breather tube where a large 3 or 4 inch black hard plastic tube runs up from the front RH corner of the engine bay, up the RH side of the engine bay, then curves over to the top of the throttle body...? These cars will not run right without this tubing and the MAF sensor plugged in.
When you put the key to the on position, just before you crank it, can you hear the throttle body going thru a bunch of adjustments? If you look down the bore of the throttle body what position is the butterfly in? Is it all gummed and clogged up?
Is the throttle body plugged in at all it's plug points?
Check to see that there are NO missing vac lines or tubes (there are a couple that are hard to see) missing at the throttle body. Do you hear a loud HISS (air) when it's reving up to that 4000?
And, do you turn it off at 4000, or does it **** itself off/stall?
DavidYau (07-18-2021)
xk8 stalling issue
Thank you for your reply and suggestion
The car belonged to my cousin in Athens
Greece and i bought it from him 2 years Ago.
The car was in good working condition but
sinve the pandemic last year,it was just sitting there.
I live in New York and could not travel to Athens.
We passed the inspection and the car is in working
condition with this issue that just came up.
I am in the process of changing the shocks,and
doing repairs on the interior to bring it back
to a good order.
to a good order.
