2001 XKR head rest motor not working
I originally posted this in the wrong model category - so I'm re-posting it here.
I have a 2001 XKR. The driver side head rest doesn't adjust. I read the post regarding the headrest cable sheath problem. My problem however is that the motor doesn't activate at all. The other seat motors are working fine, so I think it can't be a fuse.
Any ideas?
Thanks!
Steve
Any ideas?
Thanks!
Steve
That sorta leaves the switch, the connectors, the motor or the seat control module. Then these cars have a propensity to rub through the wiring insulation which usually produces a blown fuse (#1 and #8 driver fascia panel).
There are relays on the module board but no one has yet come up with the schematic for board itself.
You might try swapping the module with the passenger seat one while checking the connections under the seat.
A JTIS down load is available here:
https://www.jaguarforums.com/forum/s...ead.php?t=9933
It has all the years up through '03 and electrical schematics.
X_Type_South_Africa
12-09-2015 05:37 PM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
