2001 XKR - Misc Issues
Guest
Posts: n/a
My wife's '01 XKR is having some issues, that I need to get dealt with. The first is the dreaded green bleed from the center of the top. Unless I can do a splice, I'll bite the bullet and take that one in to let the dealer do it. A 6 hour repair is not in my cards. So - the question is - I am assuming the hoses are probably too deteriorated to repair?
Next - the Nav unit gives an "error reading disc" error about half the time. I was going to buy a disc for it, but I am not sure if it's the disc or the unit. Anyway to tell, other than buying a new disc? Also - any sources for it?
I'm a bit ofa newb when it comes to fixing this car - it's her car, I don't fit in it, and I generally stay away from it.
Thanks.
Thanks.
Received 2,192 Likes
RE: 2001 XKR - Misc Issues
to replace the hoses, you need to remove 3/4 of the interior, drivers seat, back seat, half the carpet, and hear rail, youll see the hoses and how they route. My recomendation, have someone else do it, for most its worth someone that knows how to do it, fixing it.. Try cleaning the disc for error
My nav unit also sometimes has an error reading the disc, and it is totally random. i tried a new disc, and that does not fix the issue, so don't go buying one. my next attempt will be to clean the navigation dvd unit, compressed air and maybe a pickup cleaning if that doesn't work.
Beardy
09-18-2015 10:00 AM
