2001 XKR oil cooler
Old 09-07-2012 | 09:10 PM
raphell's Avatar
Default 2001 XKR oil cooler
I have removed all four retaining nuts and onhooked both lines. Now how do I get the cooler out? There doesn't seem to be any way to remove it from the brackets.
Old 09-07-2012 | 10:17 PM
BlackX300VDP's Avatar
That should be it. Are the brackets bent? That usually happens on those oil coolers. the brackets should be level to the ground.
Old 09-09-2012 | 01:20 PM
raphell's Avatar
So the nuts should face the ground? Mine kind of face the front so the cooler would have to go into the radiater to come off. Should I just pull on the top of the oil cooler to straighten it up? I really appreciate your help. I am hoping that a radiator shop can fix my cooler so I don't have to get a new one.
Old 09-10-2012 | 08:03 AM
You are correct, the nuts should be facing the ground. Just bend the brackets back so they are level with the ground and out she comes.
raphell (09-10-2012)
99xk8guy
05-28-2024 10:36 PM
toronadomike
08-07-2022 04:41 PM
GordoCatCar
01-02-2017 02:10 PM
Scarecrow
03-28-2016 04:17 AM
skadmiri1
09-09-2015 12:27 PM
Quick Reply: 2001 XKR oil cooler
