2001MY XKR Fuel Pump Flow Rate
The secondary fuel pump on my car has failed. Avos has just installed a 2.6hl twin screw to my car. I could replace the 2nd pump with stock but think for the price of the jag item, I could do something much better.
Any ideas? No bar room talk. Want folk to reply who have good experience please as this tank is only coming out once. Thanks.
Now have the dyno results in for the standard fuel pump fitted to our XK8/XKRs. They are as follows:
12.5vdc
43psi/108ltr/6.5amp
58psi/73/7.5
65psi/55/8
73psi/53/8.3
13.5vdc
43psi/135ltr/7 amp
58psi/101/8
65psi/87/8.4
73psi/65/9
Hope this helps. I am supposed to be getting full graphs sent out at some point but I think these figures capture the key points.
(Of interest to all, but probably aimed at those who run Kenne Bell Twin Screw conversions).
12.5vdc
43psi/108ltr/6.5amp
58psi/73/7.5
65psi/55/8
73psi/53/8.3
13.5vdc
43psi/135ltr/7 amp
58psi/101/8
65psi/87/8.4
73psi/65/9
plums (05-02-2012)
Sorry, my computer is having trouble with Adobe right now and I can't open the files.
But I wanted to ask, are the units in your second column Liters per hour?
Also, if I recall, your British Litre is slightly different than the Liter we are accustomed to here in the US. I assume they measured the pumps in your units?
Err .. go with the European measurement. That is ISO
Liter ... no, the word is litre. Gawd.
Thinking along similar lines. Any issues, other than the mod to fit. I assume you soldered the fittings and shrink wrapped the join?
Charlene n John
09-28-2015 06:01 AM
deanh
09-06-2015 08:20 PM
