2002 headlight question
I picked up a 2002 XKR. Right headlight dip beam( low beam) inop. Pulled the round cover off and found that the previous owner rigged up some kind of bulb by cutting and splicing. I got the correct bulb and can’t figure out exactly what he did. An HID bulb was direct wired into 12 volts by previous owner ( no igniter ???). There apprars to be a 2 pin connector hanging loose. The original bulbs took a braided connector. That connector appears to be MIA along with the wire clip that holds the igniter with bulb into the projector housing. I can’t seem to find any detailed pics or instructions.
any helpful ideas out there?
thanks in advance
sorry for posting this originally in the wrong forum
thanks in advance
NikolaiDiqnov
12-01-2021 03:04 AM
