2002 Jaguar XK8
Welcome to the forums Stephen,
I've moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to help.
When you get as minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Battery cables
Stephen,
First thing DIY to check is the state of the battery. Is it in the car? You don’t mention if you’re handy with a wrench in the garage. Do you have a multi meter to check the voltage independently?
Is there zero power to anything? Is the car 100percent dead? My guess would be bad battery cables. Take trunk floor panel out and see. Are the battery terminals clean and tight? Worth checking both ends of both cables and the body terminals. The positive cable goes to the High Power Protection junction box. This bolted connection can work loose.
Good luck.
Good luck.
William Brooks
01-19-2019 03:21 PM
jaguarcat
07-08-2014 05:21 AM
BugDoc
01-26-2009 11:06 PM
