2002 XK8 Convertible rear speakers
My rear speakers aren't working. The previous owner said she had the top hoses replaced. When the top is down if you look into the well on the driver's side I can see a wire that comes from the speaker with a connector on it, but is not connected to anything. I can't see what it's supposed to connect to. Are there any posts or anything that shows how the speaker wires are routed?
Thanks for your help!
The rear speakers are mounted backwards, with the magnet and plugs facing the grills. The only way to really plug them in is to remove the sides of the rear seat, which includes the rear seat. If I was going through all this effort, I would be replacing the speakers at the same time. The stock speakers(woofers) tend to have around a 10 year life span. It is not a HUGE job, just a little time consuming.....Good Luck.....Mike
jamdmyers
02-01-2016 05:39 PM
