2002 XKR 100 timing chain tensioners
It looks like it's time to swap out the timing chain tensioners, she's got 60k and I'm hearing a bit of chain slap at idle.
Dont know if I should go all apey and replace both sets, the slipper guides and the chains ...etc. I think it should be properly documented too. I don't think it looks terribly complicated but has anyone else run into trouble?
What do you guys think?
The 2002 model year is a mixed bag. Conversion to metal tensioners occurred on August 13, 2001 so many '02 MY cars have the latest metal tensioners. My '02 was manufactured in June '01 and had plastic tensioners. I think that the XKR 100's were all manufactured after the conversion. Check the driver 'B' column for a label that states the manufacture date. After August you have the latest and best so just enjoy.
Hi
Think Test Point is saying your model should have metal Tensioners. these dont need replacing. However if you can hear what could be chain slap, remove cam covers and look at the tensioners to see if they are metal. if they are see if the chains are under tension.
If the tensioners are red or brown in colour then these are the type that fail. look to see if they have lost shoes. replace ASAP.
Best Wishes
Steven
to carry out the checks above will take a couple of hours
Best Wishes
Steven
Never heard of these engines having a timing failure - they are the 'Evo' 4 litre, meaning they have,
4.2 oil pump and pick up
4.2 Morse 'silent' triple link timing chains, primaries
4.2 all metal timing parts
They are the bullet proof unit, I own two and service a number of them.
Are you sure it's chain slap, I'd suggest a number of other things. What oil weight is in the engine currently, and type and age?
A complete timing refresh can be done in under 4 hours with the correct tools.
Here is what it looks like inside when I replaced the upper tensioners which are most critical.
https://www.jaguarforums.com/forum/x...ics-how-52653/
xamyel (10-11-2012)
Beardy
09-18-2015 10:00 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
