2002 XKR or 2006 XK8
The only real "update" was the two piece seat, which the 2002 should have anyway (the update came in 2001) (unless the XKR has Recaro seats, and those are better anyway) Apart from that, I can't think of anything that should have changed appreciably.
The only thing to keep in mind on the 2002 is it will need (if it hasn't been done already) upgraded secondary timing chain tensioners to the third generation metal ones.
Many 2002s have the upgraded tensioners, but they need to be checked to be sure, or else get the engine serial number and make sure it is after August 13, 2001. A cooperative dealer can look up the engine serial number from the VIN.
06 has upgraded body panels, front and sides.
I'll be the odd guy out...
What is your intended use of the car? While the XKR does have more power remember it a supercharger so power is mostly when you are "getting on it" during normal driving I don't think you will notice the difference. Parts for the XKR are more expensive, adaptive shocks, etc.
Personally I feel the XK8 has plenty of power except in the stop light racer category but it still move quick.
I'd go for the 06 XK8, IMHO. 4 years newer, restyled body and less issues than the 02 XKR.
How often do you think long term that you'll go, I wish I had the less powerful car.
Just curious, what exactly in an 05/06 XK8 is easier to work on than an 02 XKR?
ok, thru 05. Based on what I have seen here, the super charger is a extra pain to deal with then you have to fix anything under it and with parts becoming harder to find for these cars, I would pass on the XKR for that reason alone.
Take the older XKR. More power and IMHO the better body style. (personal preference, no brick attacks please
The only downside is the R model likely has the nav unit. I prefer the 3-gauge setup. The nav unit can no longer be upgraded and the maps will be outdated.
However, the '02 should be less money despite the R package. Better check condition, no matter which way you go.
![Icon Bricks](https://www.jaguarforums.com/forum/images/smilies/icon_bricks.gif)
Dicque
09-19-2015 12:53 PM
