2002 XKR conv. pass. window
Try to reprogram your window. To do this you push the window down button and hold until you hear or feel a click. Then push the window button for the window to close and hear or feel the click. This should be done when you are in the car and the door is closed. The window should operate properly by opening a slight bit when the door is opened and close when the door is closed.
This problem is often caused by a weak battery voltage. 10.5 or below they loose memory settings.
Terry Alan (12-22-2015)
sounds like a window adjustment you can try to perform this yourself,i have seen many over the year.
once you remove the door panel you will be able to see the mounting points for the window regulator some have slots in the body,the ones that are slotted you may be able to see that the bold has slid from its original mounting position simply lossen and repletion,i would recomend having it done by some one who has done this in the past
I would try that 1st and make sure you have nothing binding on the window tracts
99xk8guy
06-05-2023 06:28 AM
Dicque
09-19-2015 12:53 PM
