2002 XKR Transmission Fault
Old 04-11-2017, 09:51 AM
rjulius's Avatar
Per RJ, I started a new post with research on the conductor plate part numbers, and ended up collecting all the part numbers for the whole job, along with an index of links from our forum and from BenzForum, which has all the DIYs. I also loaded a few PDFs of detailed transmission manuals. The idea was to put all the research in one place: https://www.jaguarforums.com/forum/x...-plate-179045/
BTW, the replacement was very straightforward. And the valve body doesn't weigh that much (someone on the Benz forum estimated 30 lbs, but it's more like 10 lbs) so you don't need to work out for a month bench-pressing in order to get the job done. Shifts nicely now!
What next to fix...
RJ237 (04-11-2017)
way2far
08-31-2022 09:26 AM
cissdm
05-03-2016 06:02 AM
Dicque
09-19-2015 12:53 PM
skadmiri1
09-09-2015 11:27 AM
Numwen
09-06-2015 12:30 AM
Quick Reply: 2002 XKR Transmission Fault
