2002 XKR transmission Fluid Change
Guest
Posts: n/a
I have 22k on my Kat. Recently the transmission began acting funny.i.e buzzing noise when changing gears. I decided to replace the fluid. Dropped the pan and found contaminated. My question is how do YOU Drain the excess fluid in the torque Converter?
I tried cycling the gears but little fluid came out.
Help Help
Help Help
ORIGINAL: FactoryJaguarTech
Contaminated fluid would be a result of a failure. If you have metal filings in there, prepare to bend over and take it without lube.
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
At 22K that's really early for tranny failure!!! How long you hand the car?
Beardy
09-18-2015 10:00 AM
