2003 AC Compressor should come on???
I noticed today, about 20 outside that my ac compressor was not engaging when the AC is turned on or it if the window defrost was turned on.
I had the temp set to LOW, nothing, turned on defrost (ac's button light came on) and still not clutch engaging/spinning.
If it is 20 or so outside just turning on the AC the clutch does not engage? Should it if you turn on the defrost??
The AC was cold as ice this past summer/fall.
This procedure will allow you to pull the codes from your climate control panel along with code definition.
Link http://www.gusglikas.com/images/Auto...or%20Codes.pdf
I hope this helps
I hope this helps
I did take car to car wash and sprayed down the front of motor and radiator area of rad fluid. Maybe there is water in a sensor that needs to dry up to allow the ac compressor to turn on. The ac unit and around it was dirty so I hit it good with water. I suspect once it dries it will start working. I have ALWAYS used spray washed to clean my cars, this car is a bit finicky when water hits ANYTHING.
If you look down between the two fans attached the a pipe going from the left to the right of the engine bay.
Link http://www.jagrepair.com/images/Auto...s/ACSystem.pdf
Look on page 4
Look on page 4
