2003 Jag tensioner questions
I have a 2001 XK8 with a bad engine due to chain failure. I have located a 2003 engine. Have all the chain/tensioner problems been addressed with the 2003 engine? The engine is more expensive to buy but would be cheaper in the long run, if I do not have to replace the timing chains and tensioners. I have been told a 2003 engine will fit a 2001. Thanks
The '03 engines, as did the late '02s all had the metal tensioners. The '03 4.2L engines can be swapped but involve a lot of issues that will substantially increase labor cost. Here is some discussion on the subject:
https://www.jaguarforums.com/forum/s...63/#post177881
As to your engine issue, it depends. What kind of issue do you have? Your description is a little too vague to offer any suggestions and why do you think this issue is tied to the tensioners?
xjrjag
10-27-2021 11:48 PM
FS[MidWest]: Secondary Timing Chain Tensioners
Bcrary3
09-12-2015 08:43 AM
Bcrary3
08-31-2015 11:29 AM
Andrew McVey
16
08-27-2015 07:21 PM
