2003 XK8
When you say that the plugs are wet, do you mean the body of the plug above the threads? If so the oil seals in the cam cover are leaking and you need to replace them, but they are part of a cam cover set. Your mechanics comment about reseating downflow oil tubes makes absolutely no sense.
The following 6 users liked this post by RJ237:
Dr. D (01-04-2024),
JimmyL (12-29-2023),
michaelh (12-28-2023),
motorcarman (12-28-2023),
Y2KJag (12-28-2023),
and 1 others liked this post.
The following 3 users liked this post by Y2KJag:
thegreatgarbanzo (12-29-2023)
1. get a new mechanic - he's talking through his downflow tube.
2. buy and fit replacement seals (see RED lines)
The photo is my 2001 XK8. I also replaced the front seal (see GREEN line) as I had the covers off but this wasn't strictly necessary. You WILL need new camshaft cover rubber gaskets (arrowed in BLUE).
Do NOT OVERTIGHTEN the cover bolts. It's the quickest way to crack a cover and subsequently induce further oil leaks.
If he meant that the plugs show signs of burning oil then you have a different problem.
I suspect the gasket change will fix your issues. And you should consider finding a new mechanic.
Received 1,674 Likes
Y2KJag (01-04-2024)
Dr. D (01-04-2024)
Received 2,390 Likes
^^ +1
NB also RJ237's point about the seals. Jaguar calls them O-rings, grommets or isolators, depending on where you look. They flatten and bake over time, and are key to maintaining a good seal with the cover gasket as it is they which provide the clamping pressure on the cam cover.
To repeat, go gently on the bolts. The manual states 12Nm, I went for 10 and no leaks. Coil pack & coil cover bolts, 5Nm (not much more than finger tight).
