2003 XK8 how do I fix 'asc not available'
Welcome to the forums, You might try this link and do a search of the forum these failures have been often discussed, here's 1 link
https://www.jaguarforums.com/forum/x...e-fixed-94566/
Also you will have a Mod come by shortly to ask you to introduce yourself!
The link in post #2 should answer your question.
AK,
Are you getting the ABS light as well? If so, your ABS sensor connections may be losing contact. In one case, I ever so slightly bent the pins in the sensor, then very carefully re-seated the connector. This ensured a more positive contact. I've also used electric grease to seal the connections. It's been many months since I've had a problem.
I used to clean my sensors every time the problem came up, but then I realized that it wasn't the cleaning that made the problem go away (for a while), but it was merely pushing the connectors back on. Don't even bother to take your tires off. Just reach in there and push those connectors home a bit. If your problem goes away (for a while), you've nailed down the cause. Then just refine the solution.
99xk8guy
06-05-2023 06:28 AM
neruda
10-18-2015 01:19 PM
