2003 XK8 leak at back of transmission pan
I recently witnessed oil stains under the car. Upon investigating, it looks like it is leaking at the back of the pan. All bolts are tight and leak does not appear to be coming from anywhere else. Pan was installed about 5 years ago and no issues until now. Car has only been driven about 7K miles.
Do these plastic pans fatigue in some way? Has anyone seen this before? Looking to learn before I drain and replace the pan.
I'd say the same thing, it is likely the connector sleeve seal. Best is to inspect it from under the car, but it is sort of dead center, so you likely have to lift all 4 corners. If you suspect a leak, first clean everything with a degreaser, drive some more and then re-inspect. I suppose there is the possibility of an output shaft seal leaking too, but it is not common.
Best of luck, keep us posted.
That is the bridge seal. It goes above the valve body. It is known to wear and cause issues. If you are up to it, "while there" with the pan, you can remove the valve body and replace that bridge seal, as well as count (4) tube seals in the same general area. This is all done from the bottom pan, the transmission remains bolted o the engine.
The following 3 users liked this post by fmertz:
Well, I replaced the tube seals, the wiring sealing sleeve, the bridge seal and the oil pan.
If I were left alone with the guy who designed this car and did not provide a better way to fill it without dealing with hot exhaust pipes I would probably end up in jail.
This is never a fun job.
Pantera928 (05-25-2021)
alextovaar
03-16-2015 12:46 PM
