2003 XK8, Torque App, Android, Bluetooth
Hi All,
The above combination only partially works for me. In particular, Coolant Temperature says "No Data". Others, like RPM, show OK. Suspect it is the (very) cheap Bluetooth ELM327 interface I have but reluctant to buy another without some assurance it will work fully.
Dashcmd app on the same Android phone and a WiFi ELM327 interface works fine so the PID is obviously available. I find the Torque app to be more user friendly so would like to use that if possible.
It seems also that Torque on Android cannot connect to WiFi interface.
I have scoured the prior threads on similar topics without finding an answer.
bazjag (02-15-2016)
I have the ELM327 Mini - was an $8 one and the Torque App, going to my Samsung phone and tablet, iot shows everything, I use it as a temperature sensor gauge on trips until I get the Real Gauge installed. I use it on 3 cars, all work great and neighbours are starting come over to get their error codes read. 8$ ofr ELM327 Mini and $5 dollars for the Torque app have to be the best $13 I ever spent. Hooks up via bluetooth.
bazjag (02-15-2016)
My Torque Pro and cheap ELM knock off works fine on the XK8 and several other cars. I went through the PID's and all supported were there.
It should be noted that I have 4 of the cheap ELM devices and only one works. Obviously, the sellers understand the failure rate because I have never had a problem getting my money back through eBay.
bazjag (02-15-2016)
Yes I am using Torque Pro. It does work fine with my Saab. My '97 has a build date of Nov '96 so it likely has the earliest ECU firmware. 3 of the adaptors all fail the same way with it but they all worked on the other car. I figure its just the ECU isn't outputting the data. I even bough an old Android tablet I was gonna keep in the car to use as a temp gauge. Same problem with that as with my Moto X phone. No data for temp.
Dave
Dave
bazjag (02-15-2016)
Thanks to all responders. It seems that the consensus points towards the Bluetooth interface being the problem. Some work, some don't. Bit of a gamble. Looks like the BAFX suggested by dennysjag is a strong possibility. Only problem is that it costs $75 to have sent in from US to Australia. Looks like I'll stay with Dashcmd.
Lots of cars don't have an oil pressure sensor (other than fail/no fail, but even that is commonly not available via OBD).
For oil temp (EOT) you can check whether the car supports the PID and if so go from there. https://en.wikipedia.org/wiki/OBD-II_PIDs
bazjag (02-20-2016)
Harry Dredge
02-15-2016 11:16 AM
