2003 XKR airbag warning stays on
2003 XKR airbag warning light stays on. SRS CODE B1342 Control module internal failure and CODE B2692 Passenger safety belt buckle switch circuit fault. I replaced this with a new one and I get same reading as above. The car was not in an accident. What module is the B1342? The car after key on for 2 minutes gives of 5 beeps 5 different times then quits.
My RCM will no longer respond with scanner. I got another one which has to be flash programed. Jaguar told me $400.00 charge with no guarantees. If the tech took 30 minutes to program is the module that 30 minutes included a coffee break. The 5 beeps went away and the yellow light doesn't bother me. If it did I would remove the bulb. I will live with it until I find a reasonable charge for programing.
AmDazed
01-24-2019 10:10 AM
10-08-2012 04:24 PM
