2003 XKR Oxygen Sensor Question
Check the fuel pressure sensor at the end of the fuel rail, passenger side. It occasionally leaks from the body. It is gas, so it evaporates quickly, but you should be able to tell if you investigate quickly enough after smelling gas. I had P0193 to go with it, FWIW.
Other possibility is either of the DREADED fuel dampers on the fuel rail. Somewhat expensive part, with iffy chances of success on the part replacement apparently, and takes some work to get to as well. Some weld these shut. They are about mid-way along the fuel rails, in between the middle injectors.
Best of luck, keep us posted.
thefixer
06-14-2020 09:51 AM
