2003 xkr purge control valve
Remove the left hand front wheel, and the plastic wheel well liner. This will expose the purge valve on the right side of the wheel well. It should be a pretty obvious swap from there. An electrical connector and 3 or 4 hoses will need to be disconnected and 2 or 3 bolts removed. Be sure to check the hoses for deterioration and replace if necessary.
I want to change my purge valve as in Tech Bulletin 303-63.
When you say Remove the left hand front wheel is that standing in front of the car and looking at the bonnet (hood) or is it when sitting in the driver's seat??
Also, when reading TB 303-63 it says to replace the hose and filter, showing the filter sitting next to the brake master cylinder. When I look around my brake master cylinder there is No hose or Filter?? My car is a 2001 XK8 which is supposed to be covered by this TB (1999-2002 MY XK range).
Any help will be appreciated, ny wife says the smell must go!!
djpxk8 (04-07-2011)
-Regarding the hose and filter in the TSB, they are new additions for use only with the redesigned purge valve...that is why you do not see them on your car.
djpxk8 (04-07-2011)
djpxk8 (04-07-2011)
djpxk8 (04-07-2011)
Try Jaguar Parts Center - Call (800) 510-1401 for Genuine Jaguar Parts and Accessories online
or
Nalley Jaguar
http://www.nalleyjaguar.com
Phone number: 888-531-2266
11507 Alpharella Hwy
Roswell, GA 30076
(order by phone, but free shipping and 15% off over $25 for forum members)
or
Nalley Jaguar
Roswell, GA 30076
djpxk8 (04-07-2011)
OkieTim
09-08-2015 04:48 PM
