2003 xkr rear a-arm bushings? do these wear a lot?
reason i am asking is that i went for inspection and the mechanic was able to move/rock the rear wheels a bit (fronts are tight). His guess was the rear a-arm lower bushings....both sides rock the same though so I dont know if they are both worn or if thats the way they are supposed to be??? If they do wear a lot and should be replaced, go with jag originals or are there better aftermarket bushings? I assume these are solid busings in the arm? or are they rubber? thanks for all responses.
Beardy
09-18-2015 10:00 AM
