2003xk8 trunk?
2003xk8 trunk?
trying to help a friend out lost his manual. batt went dead cant seem to find out where key goes for manual trunk opening?also he teels me you cant open the trunk or gas fill door unless engs off and key is out of ignition? with batt dead i used a jump pack on to pos cable at under hood fuse box.ign off and key out would not open trunk or gas door.but i was able too start car with jump pack cked charging voltage good. next ? ileft the car runnig so he could charge the batt after this runs for awhile do you think that mode will reset?and trunk will open? thanks for any help
Be advised the lock will probably be stuck so you will need to squirt some lube in it. I had to apply some downward force on the trunk lib also to get the lock to release.
XKR trunk key hole out of line with hole in badge
I have a 2005 XKR convertible. After wondering how to get into the battery if it was flat I found the key slot in the XKR logo but could not get the key in. Now I found the car has the mechanism fitted in the trunk and the key fits and works. The problem is the hole in the XKR logo is about 1 inch (25mm) out of line with the mechanism inside the trunk. The key hole should be about the centre of the X. The only option is going to be to move the logo to the right as it seems to be in the wrong place (even though it looks OK) Anyone tell me how the logo is attached or experienced this issue before? Cheers
Still has the blue paint on the key hole
The key hole should be about where the X is located
Can see the metal of the XKR badge when looking from the inside
