With Motor man's knowledge about this subject, and based on VIN# I was able to quickly locate and purchase the correct eye on Ebay for only 18 dollars shipped! As a 40 year British car fanatic/owner, and currently own a 91 XJS V12 convertible and 2003 XKR convertible....Never have a seen a more confusing subject for a really simple part. I look forward to never having to use it here on Cape Cod Massachusetts.
We will have to make the trip. For the ice cream of course, and to see some family history; My SO’s distant ancestors once owed Martha’s Vinyard back before the civil war. I’m sure it was just a mosquito infested swamp back then.
Z
PS. my ‘02 XKR VIN ends in A24583 and of course the tow bolt is missing, the rest of the “kit” is there though. Still Not sure which bolt to order or from where
Found another alternative for a replacement tow hook. I noticed mine was missing out of my 2003 XK8 a couple of weeks ago. Finally figured out mine was the M20 x 2.5 version. I went to the salvage yard today, but every Jag I checked was either missing its tow hook or had the wrong one for my needs . So I was checking out some different vehicles I had read might have the same thread specs. No luck on the VW or Mazda. Finally found one that was a perfect fit. It came out of an 2007 Hyundai Accent of all things! Works on the front and rear and fits perfectly. The best part was the cost $3.25! Can't even buy an eye bolt for that!
And it fits in the jack kit under the spare with only very minor alteration. Less than an inch of Styrofoam was removed to allow the longer shaft to fit. Kit w Accent tow hook
Genius! This worked for me. Got it on eBay for under $20 used and is a perfect fit on my 2000 XKR. Thanks!
I just ordered a couple of tow hooks from McMaster Carr, an industrial supply house here in the US, if you're not familiar. 150mm long and I'm trusting you guys on the M20 x 2.5 being the right size. I checked my car and low and behold it's not there. Where in the heck are these things going??? Is it too hard to put it back??
I'll let you know when they arrive. TM
Well, my eyelets came and they do not fit. I couldn't find a way to measure the hole as it is recessed a bit and the hook would require a bit of shaft to get the eyelet out oil the open.Bottom line is M20 is too big, I should have paid closer attention to the above post advising M16. I'll see what I can find. BTW, the industrial eyelets are too short, there isn't enough shank to reach the recessed hole. My serial is A30811.
