2004 XKR Headlight Leveling Linkage
Does anyone know where I can get the linkage to connect the headlight leveling switch to the lower bracket for a 2004 XKR? I can't seem to find the linkage as a separate part. US sources would be good but any source would help. If this question has been asked before, I couldn't find in the posts. Thanks for any help.
Linkage is number 1
My 2004 XKR
Linkage is number 1
My 2004 XKR
Hi jurczak1
It's one of those "You will have to buy the whole item, sir. That part is not available separately"...
Member PKWise managed to engineer a replacement. It's for the rear, but I imagine that something similar would work at the front:
https://www.jaguarforums.com/forum/x...4/#post2246786
or you might find one in a breaker's yard.
Thanks, Jon89, that's a good idea. It is much smaller than a sway bar, but I think I could make something that can do the job if I can't buy a replacement part.
Does anyone have the measurements of the linkage from center of ball to center of ball or a drawing of the part? The repair manual doesn't show the linkage and I don't have the original part.
giandanielxk8 (07-06-2020)
I finally inspected mine today. I didn't just loose the linkage, I also lost the plastic linkage to the sensor. I rotated it by hand and the sensor still works. It was in the highest position that must be why I couldn't see very well at night. I set it to its lowest position. I think I will have to order the entire sensor. Or maybe I can come up with some solution...
