2005 XK with window problem
The limit switches need resetting every time the battery is disconnected or if the battery is suspect.
If this doesn't fix it, run a search for "window limit switch" for threads on failed switches.
___________________
2005 XK8 4.2-S Coupe
rjc57Jf (01-13-2012)
rjc57jf;
In addition to the advice of GGG, and if you have to go deeper into a repair, Reverend Sam has a series of videos which include the removal of the door panel and window adjustment. A number of the videos can be found in the FAQ section or open any of Reverend Sam's posts and there is a link to his videos.
99xk8guy
06-05-2023 06:28 AM
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
