2005 XK8 ABS sensor wire harness replacement
Hi guys, I am getting C1145 which points out to front right wheel sensor open circuit....according to the reading in this forum it's most probably my wire harness...because it's intermittent.
So is there an instruction on how to replace it... I know it's just plug and play but it's better if there's an instruction somewhere.
You might want to check on availability also. From memory, I seem to recall reading on this forum that some of those wires were no longer available from Jaguar, so folks were fixing theirs instead.
LJG3410AC and LJG3410FC for $120 for both.
I cleaned the sensors last summer...can't be that fast for them to get dirty again can it? well worth a try I guess.
zidjan (01-14-2016)
thedugger1
12-16-2015 06:16 PM
S-type 2000
12-16-2015 06:53 AM
