2005 XK8 expansion tank capacity
I have just changed my coolant and the expansion tank was empty. My understanding is that it's supposed to be half full. I disconnected the hose from header tank and attempted to suck out the old coolant but none was present so I added about a quart with a large serenge (spell check) . If I knew the capacity I could get it right without removing fender well.
Jack
Jack
With a good torch you can see the level in the tank through gaps in the A pillar region when the passenger door (for LHD cars) is wide open. Last time I had the wheelarch liner off I added green and red tape to the tank wall that I can see from outside.to mark the level I want to maintain.
Thanks again astromorg, I checked and can see it very clearly. I need to add a lot more as it looks as though it's almost empty. Makes me wonder how many of us are running around with empty expansion tanks wondering why low coolant light comes on so often when it only takes a touch of fluid to top it off.
Stumpy (07-24-2023)
Rubbish ...half full is correct ..how can it suck back if its empty . The pipe up to the expansion tank needs to be full for the expanded coolant to shuttle back and forth.
and the liquid in the overflow tank allows air to come out the pipe and be replaced with fluid.
"Rubbish" is best avoided unless you're 100% sure that you know what you're talking about. 😉
Richard
If the tank is half full it will take care of evaporation for a long time. If you start out with an empty tank the level in the header tank will go down just a tad every heat cycle. That is was what I was experiencing. Now my tank is half full. I'll keep and eye on the header tank for a while and see how it goes. Also, if there is coolant in expansion tank it will cool the hot pushed out coolant and slow evaporation I would think.
And the tank with the filler cap are indeed the Expansion tank.
zray (07-25-2023)
giandanielxk8
01-25-2021 02:02 PM
